11 minutes ago, BloodyWaters said:
Every GPU I've ever owned, when stress tested, never goes up to 100% load. It stops at 99%.
Don't know why, but that's the way they were designed. Every GPU you have owned and ever will own will never reach 100% usage. You're not losing any performance from it. Just that it's not reaching 100% load.
https://linustechtips.com/topic/722567-gpu-load-question/#findComment-9197213
If you benchmark enough you will see it.
https://linustechtips.com/topic/722567-gpu-load-question/#findComment-9197419
