Need some help to buying a laptop for College
Solved by Sauron,
3 hours ago, subha said:It's quoted on the user manual that maximum ram supported by my system is 8gb. And I'm already using two 4GB on each slot. Can I extend it to more? I mean 16GB?? Will my laptop's motherboard support that ram?
Well, this page claims it supports up to 16GB of ram. When you bought it it probably said "up to 8gb" because single 8GB dimms weren't available yet. Of course, you'd have to remove your current ram sticks to make room for the higher capacity ones.
