Hi I will be building a pc soon.
Was wondering if someone can tell me if this sound card is compatible with this motherboard
Gigabyte GA-Z87X-D3H Motherboard
http://www.pccasegear.com/index.php?main_page=product_info&products_id=23562
Creative Sound Blaster X-Fi Titanium PCIe
http://www.pccasegear.com/index.php?main_page=product_info&products_id=8169
If anyone is interested here is the parts list I plan to use
https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=224821&action=wish_lists
Thanks for the help!
https://linustechtips.com/topic/72224-sound-card-compatibility/
Yeah but I wouldn't buy the sound card if I were you.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/72224-sound-card-compatibility/#findComment-989021
I  have seen and read conflicting view points on the recon  3 sound card but what I would get is the creative sound blaster z
Thanks for the replies,
Would you recommend this sound card over the other one for $89?
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18681
https://linustechtips.com/topic/72224-sound-card-compatibility/#findComment-989182
Might want to take a look if you can get the MSI GD45 or the Asus Maximus VI hero. Those boards have great on board sound aswell. Then you don't have to consider getting a dedicated sound card.
Incase you really do want a sound card. Personally, I would go for an Asus one. Despite the fact that I have the sound blaster myself, bought this without research done haha. It's not a bad card tho, but.. If I would buy one now, yes Asus!
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/72224-sound-card-compatibility/#findComment-989437
