Okay so, this is what is happening. I have green lines that are moving randomly as things happen on the screen and they are horizontal. I have tried everything I can think of. Removing drivers, reseating the gpu, removing/attaching power connectors, switching slots. The other thing is that I can only use one video port at a time otherwise it does not detect a signal. All ports work, they just have to be individual. When I boot up and everything loads, nvidia message pops up saying no compatible hardware detected. It was working just this morning ;w; the only thing I've done is added a noctua cooler to my cpu. Please help, I'm not entirely sure how I'm getting a video signal at the moment but its a weird resolution but its what I got. I've also tried multiple monitors
http://imgur.com/a/pbXlj
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/
That actually looks pretty cool imo :P
On the other hand, try checking if your card is overheating? It could be the issue, though I doubt it.
Try using an adapter? It could be the port, a DVI to HDMI would be a good one to start, since they rarely get used.
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185815
I have tried, i am using an adapter already xD But uhm.. It shouldnt be, the fans are on. It does this the second its on and its been off all day
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185821
Its probably dying. Based on what you've told us, you've tried basically every fix possible and those green line look similar to the last dead GPU I looked at. Out of curiosity, what GPU is it?
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185822
GTX 760
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185827
Alright, mate, heres the story. I have had the same green lines on my computer before. The fix was pretty simple...if I were to have caught it. The thermal paste, between your heatsink and the actual graphics chip has been gradually burnt away. Simple fix: remove cooler, re-apply thermal paste-stick cooler back on-DONE. BUT by the time I had green lines, the card was dead.
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185830
I'll remove it and apply the thermal paste i got with the cooler. Will I need thermalpads? Its the EVGA superclocked version
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185841
2 minutes ago, Kenji the Uke said:
GTX 760
As a last resort, I would remove the cooler and check for any burst capacitors. It's extremely unlikely, but its better then throwing away a potentially usable GPU. Also, replace the thermal paste while your at it.
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185848
It would, but you can use a SMALL amount of paste instead of pads if you don't want to waste time or money.
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185853
I'll try it. ;w;
Will try ;w; whats a burst capacitor look like?
2 minutes ago, anybodykek said:
He could be a cheeky cunt and sell it DOA, but I'd advise against being a cheeky cunt.
whut
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9185862
I dont think its even detecting the gpu. I think somehow its getting the onboard graphics via the gpu port somehow ;w; because it straight up does not see the card
Moist
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9186045
Try changing the video output in the BIOS from Integrated to discrete?? I doubt it will work but is worth a shot.
https://linustechtips.com/topic/721590-urgent-gpu-problems/#findComment-9186063
