Posted January 11, 2017 Wondering if liquid nitrogen would be possible or not. Not saying I'm actually considering it, I'm just curious as to whether it would be possible, and if so, if there could be any practical way for it to be integrated into consumer electronics. Let's discuss! Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 Liquid nitrogen is impractical for every day use because you need a constant supply otherwise it'll burn off or you'll need to have some expensive refrigeration equipment to keep it liquid. At which point you may as well just use the refrigerator. I have a blog! And a list of guides I've posted Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9185660 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 4 minutes ago, M.Yurizaki said: At which point you may as well just use the refrigerator. I know you're only trying to make a point but using a fridge to cool a PC doesn't work WHIPLASH CPU: Intel Core i7 6700k @4.7GHz RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz MOBO: Asus ROG Maximus VIII Ranger GPU: EVGA GTX 1080 FTW2 PSU: EVGA Supernova 650GS CASE: Fractal Design Define S Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9185679 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 2 minutes ago, toasty6776 said: I know you're only trying to make a point but using a fridge to cool a PC doesn't work "The refrigerator" referring to the refrigeration unit to make liquid nitrogen. They have those though, they're called phase-change coolers (okay, they won't bring the temps down that low, but they are capable of sub-zero Fahrenheit cooling) I have a blog! And a list of guides I've posted Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9185683 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 Just now, M.Yurizaki said: "The refrigerator" referring to the refrigeration unit to make liquid nitrogen. They have those though, they're called phase-change coolers. Yeah I know I was just trying to make a joke WHIPLASH CPU: Intel Core i7 6700k @4.7GHz RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz MOBO: Asus ROG Maximus VIII Ranger GPU: EVGA GTX 1080 FTW2 PSU: EVGA Supernova 650GS CASE: Fractal Design Define S Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9185685 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 It is possible but is completely impractical for consumer computer use. Practical use for liquid nitrogen cooling is to keep fusion reactor magnetic coils as supra conductive with active LN2 cooling. Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9190490 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 20 hours ago, toasty6776 said: I know you're only trying to make a point but using a fridge to cool a PC doesn't work I still need to try it with a walk in fridge since those have huge coolers Breaking things 1 day at a time Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9190514 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2017 52 minutes ago, TubsAlwaysWins said: I still need to try it with a walk in fridge since those have huge coolers The thing with a fridge is its cooling capacity. Fridges are designed to remove heat from a system that's not actively generating heat. A typical computer can output 300W of heat, so if your fridge can't exchange at that rate or faster, it's not going to work. I have a blog! And a list of guides I've posted Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9190840 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2017 5 hours ago, M.Yurizaki said: The thing with a fridge is its cooling capacity. Fridges are designed to remove heat from a system that's not actively generating heat. A typical computer can output 300W of heat, so if your fridge can't exchange at that rate or faster, it's not going to work. Well we will see. Walk ins are made to hande the constant load of a 6 foot door being opened and left open for a few minutes. I still want to try it Breaking things 1 day at a time Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9192480 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2017 2 hours ago, TubsAlwaysWins said: Well we will see. Walk ins are made to hande the constant load of a 6 foot door being opened and left open for a few minutes. I still want to try it But they also have those plastic thingies to keep the air from exchanging as much as possible. Usually I have a blog! And a list of guides I've posted Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9193014 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2017 44 minutes ago, M.Yurizaki said: But they also have those plastic thingies to keep the air from exchanging as much as possible. Usually Well all of the ones I have been in dont have them send who knows Breaking things 1 day at a time Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9193115 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2017 It just takes proper sizing/selection of components and refrigerant types to get a well functioning phase change system. Unfortunately I haven't completed anything for PC's yet but it's definitely in the works for me. I'm an HVAC tech/installer professionally so I've got the licensing/tools to do it, its just a matter of time I'm slowly working with my brother on engineering a controller for a used geothermal unit I got from work. Ideally I'd like to use it as a water chiller but direct phase isn't completely out of the question. Condensation is the major issue though. I plan on making a "chillbox" a sealed case that will circulate cold air and probably utilize a slow nitrogen purge as well. I'll link some builds later LTT Community Standards Welcome!-A quick guide for new members to LTT Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15 / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q Link to comment https://linustechtips.com/topic/721572-liquid-nitrogen-cooling/#findComment-9195324 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
