Hi,
My work computer seems to perform pretty badly for a computer of its stature (Xeon i5 1230, 16gb ram, some firepro gpu, and 2x Seagate Barracuda 16mb cache 500GB 7200RPM HDD's [only 100gb used], Windows Server 2012 R2 = basically windows 8).
Problem is that I'm forever waiting for things to load/applications become responsive a bit more frequent than my liking, I'm aware that everything basically works bar the odd unresponsive page every like hour but I'm so sure even with a HDD it's not this slow. Performance reminds me of my laptop at times that rocks a 5400 RPM HDD.
So I had a look in the resource monitor and didn't see anything worrying. The only thing of note is my HDD is usually low usage but occasionally spikes to like 80mb when I open the resource monitor itself. Any suggestions how I can try to diagnose this/any free HDD speed benchmarking tool. If I can get something to show hopefully I can pass this on so I can get a parts replacement or something.
Thank you!
https://linustechtips.com/topic/721328-seemingly-slow-hdd-speed/
Try using Chrystal disk mark, it's a free bench marking utility for hard drives.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/721328-seemingly-slow-hdd-speed/#findComment-9182694
You could try running Windows' built-in disk diagnostic tool, although you do need admin permissions in order to access that (which might be an issue on your work machine).
WHIPLASH
CPU: Intel Core i7 6700k @4.7GHz
RAM: Corsair Vengeance RGB DDR4 2x8GB @3000MHz
MOBO: Asus ROG Maximus VIII Ranger
GPU: EVGA GTX 1080 FTW2
PSU: EVGA Supernova 650GS
CASE: Fractal Design Define S
https://linustechtips.com/topic/721328-seemingly-slow-hdd-speed/#findComment-9182726
It looks like it's fine but it doesn't feel like it's performing at that speed.
Alright I will do thank you.
https://linustechtips.com/topic/721328-seemingly-slow-hdd-speed/#findComment-9182729
