So I got back from work after a really shity day, Started my PC and watched some video like I always do, Then went to play R6S and then my PC crash, I restarted it and now MY PC boots in to a black screen after the windows load screen, I can get it to boot in Safe mode and with about my GPU but with it in I get no signal, Which is wired and It works in safe mode, Please help me!!!! All I want is to chill out after a really crappy day :(
https://linustechtips.com/topic/721271-could-really-do-with-some-help/
Try DDU. If that doesn't work then post the full system specs.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
So I used the DDU and I can now boot in to windows, But as soon as I install my Nvidia drive again It black screens then after a bit comes up No signal in put
Can you test that card in another rig and/or test another card in this rig?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
Have you OC'ed the GPU?
Personal Desktop":
Luna, the temporary Desktop:
2 minutes ago, SlayingDreams said:
No never, Was fine and working all good yesterday nothing has changed :(
How old is the card? because the kind of issue you had comes from the GPU needing to enter it's own "safe mode" which usually happens either because its core clock is too high and the OC must be undone or because it has been facing temperature issues.
Since you didn't OC ever that might also mean you don't keep a look on its temperatures much so it could be working beyond 90Cº on games without you even knowing and it triggered the shut down to prevent further damage, so that leaves me to the question: Is your GPU very dust dirty? Try taking it off your case and clean it with those air blower thingys and a dry silk.
Personal Desktop":
I cleaned it, It was not that dusty the card and the temp in side my pc was about 28c but now it only works when the driver is not installed :(
I just don't know what to do now I tired the other card seems to work fine, done the clean install and that dose not work I just don't get it
So yesterday my PC crashed after I loaded a game up, I had to uninstall my driver to get back in to windows.
Now every time I install a driver for it, I lose signal input to the screen and have to uninstall to get it back, Dose this in 3 different systems, Is my card dead or am I missing some thing
The card is:
EVGA GTX 780Ti Dual Classified
Please help I would like to fix the card before I have to by a new one :(
9 minutes ago, SlayingDreams said:
I was thinking about getting a 1070 as 1080 is far to much price wise,  less the 1060 is a better upgrade and card
https://pcpartpicker.com/product/j8rcCJ/asus-geforce-gtx-1070-8gb-video-card-rog-strix-gtx1070-o8g-gaming
lttstore.com
3 minutes ago, Dawson Wehage said:
So there is about a £100 difference is the 1070 worth it, I kinda want an upgrade from my 780ti and if the 1060 is it and the 1070 not worth the extra 100, Then my choice is made :)
If your playing at 1080p 144hz the 1060 strix will be worth it for you. There are very good reviews on this card.
lttstore.com
