USB port help needed.
BraytonH
Hello everyone, I need some assistance with a problem I'm having. I recently have been using my PS4 controller with my PC using DS4Windows, and it's been working fine. All of a sudden, DS4 tool recognizes none of my ps4 controllers, and for some odd reason my the PC doesnt detect my controllers. sort of.
Basically, I plug in my controller to the front USB ports, and the light comes on for a second, and then the USB connection sound (do doo doop!) comes on. But still nothing. I tried using steam big picture mode, and still nothing.
Then, I plug my controller into the back, and my PC recognizes it and it works fine again. Why are my front USB ports not working with my PS4 controller? I tested them and they work perfectly with my mouse and headphones and steam controller. The front USB ports are just not recognizing the PS4 controllers.
Any help is appreciated. Thanks,
-Brayton
You know what, I fixed it. Had some missing drivers.
