I need more usb ports on my machine. Not sure what the better approach is.
Solved by RedWulf,
A hub won't add bandwidth, just split up the single USBs across more ports. That said, a powered hub will work fine for charging, any device that can't use all the available bandwidth. An expansion card will technically add bandwidth.
I would, and did, get a hub since its charging and since most devices/users are reading and writing enough at a time to be bottlenecked by the usb ports limits.
Just hop to amazon and find a powered hub with decent reviews since there are dozens.
