I have 2 build options so far, cannot choose between the 2. Another option is an intel build, but it seems as if AMD is the way to go for the money. Anybody who can either make suggestions or help me figure out some better options for the build.
Requirements:
No Operating System
No Peripherals Needed At the Moment
Modular- mostly modular besides the 24 pin to mobo cable (semi modular i think)
Would like an SSD to speed up the build
ATX Windowed Case (Mid Tower)
$900-$1000 price range
http://pcpartpicker.com/user/hlax2525/saved/2J7w
http://pcpartpicker.com/user/hlax2525/saved/2rdK
Any help would be greatly appreciated,
Thanks in advance
https://linustechtips.com/topic/72086-planning-a-mid-high-range-build/
FX 8320 is good. I would recommend the first build though. Go with a seasonic psu and G. Skill ram
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
What's the system being used for?
System is being used for gaming
Edits: http://pcpartpicker.com/p/1XHbT
