Disk usage 100%! Help!
Solved by Enderman,
1 hour ago, steVENOM said:ok, i'm glad you told me that. Really all the info on my laptop is stuff that can be moved to a portable drive, then I'll reinstall windows. I'll just copy over my libraries and my game files. Thanks for letting me know so I dont waste my time trying countless other ways of fixing it. I'm running sfc right now, so we'll see if anything comes of it.
You're welcome, I have a tutorial video on how to clean install windows too, so the process for you would be exactly the same:
