I recently had this problem with my PC where it would run incredibly slow for no apparent reason. On startup things would take 10 minutes to load up and the desktop would crash and go black. Anyway I figured that I recently installed Malwarebytes 3.0 a week ago so it's probably that. So after a few attempts at getting to the uninstall menu after frequent crashes I got it uninstalled, restarted and now everything is like it was before. Has anyone else had these problems or was it just me.
 (\__/)
(")_(")  GTX 1070 5820K 500GB Samsung EVO SSD 1TB WD Green 16GB of RAM Corsair 540 Air Black EVGA Supernova 750W Gold  Logitech G502 Fiio E10 Wharfedale Diamond 220 Yamaha A-S501 Lian Li Fan Controller NHD-15 KBTalking Keyboard
https://linustechtips.com/topic/720207-malwarebytes-30-problems/
Nope, that's kind of weird. Things work well for me. Although, I get a black desktop when I scan Rootkits, so I just don't scan Rootkit's. Else, everything works like it worked before...
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9169670
I reinstalled Malwarebytes 2.0 and everything was still worked. Perhaps it's a conflict with Display Fusion.
 (\__/)
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9169673
8 minutes ago, Factory OC said:
What version of Windows are you using?
Windows 10 version 1606 OS Build 14393.576
 (\__/)
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9169702
I believe it can be, but I'm not certain.
I use the same build as well...
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9169722
There seems to be problems with mult-monitor setups, display fusion and malwarebytes.
 (\__/)
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9169820
Had no problems uninstalling (I only got rid of it after they decided to declare a large amount of tools like auslogics disc defrag as potentially unwanted programs), but there's an errant malwarebytes service running that taskkill states actually isn't running (it looks like I'll be doing a fresh windows 10 (once I've done the upgrade) install once I get the SSD that is going into this computer).
https://linustechtips.com/topic/720207-malwarebytes-30-problems/#findComment-9173552
