Need help fixing a bum ram stick!
3 minutes ago, KarateHottie93 said:The suspect is an 8 gig stick of HyperX Fury DDR3 1333. The crime committed is a goddamned "Memory Management Error" blue screen!
Normally I wouldn't care. It's just a cheap ass stick of poor people ram. It's all I got left over for this thrown together build though.
I know it's bad because I have four other sticks of the same garbage ram from other builds that I threw in just to test. I have confirmed it's not a mobo slot either.
What do I do? Should I try cleaning first? Has that actually ever helped anyone? Should I bake it? I mean it's already worthless so it can't break much more. Need advice please!
i know i'll get shit for this, but try baking it. My LG G4 broke so i disassembled it completely, put the board into an oven for 10 minutes, and it worked. If it's worthless, the oven thing is worth a shot. If you don't wanna harm your oven, what i did is wrap it in 3 layers of tin foil and throw it on the bbq/grill.
