How To Automatically Play Audio On Webpage Using HTML Or Javascript?
I need to find a way to autoplay a song on my webpage, that doesnt need vlc player. The audio format is .M4A
But I also need a way to toggle it in the header, but not a player just a button, also with some effects from css.
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
Don't. Sites that automatically play music are the worst thing in the land. I want to break my computer every time I come across this.
Its just for assignment for class. Im the teacher start student so I wonna show what I can really do with Javascript, html, and css.
for html
<audio controls autoplay>
  <source src="path-to-file" type="audio/mpeg">
  <source src="path-to-file" type="audio/ogg">
  Your browser does not support this audio format.
</audio>
this works for me :)
this only works with html 5
PooKloo For Slick
