Greetings.
Im running the cards ( Two 7970 xfire)
On max overclock and text and webpages has this weird shadow.
temp is ok on both gpu. just wondering if it can cause damage to the cards?.
( only running OC because of folding )
Thanks for any awnsers :)
https://linustechtips.com/topic/71972-amd-7970-problem/
Greetings.
Pics or it didn't happen.
But seriously, any pics?
https://linustechtips.com/topic/71972-amd-7970-problem/#findComment-985512
Check in a different browser (or notepad).
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/71972-amd-7970-problem/#findComment-985523
Doesnt show on pics. weird.
Does. but then i scroll and it goes away. wird stuff.
Whats the voltage?
Stock i presume. cant change it. just using MSI afterburner. 1050MV
https://linustechtips.com/topic/71972-amd-7970-problem/#findComment-985577
