Hello, i was wondering i5 6600k or i5 6500 (i will not be overclocking, and the theme is kinda great budget pc it will be paired with: a evga 1060 6gb SC, 500w cooler master psu, hitachi Hdd, 275gb crucial Ssd, msi z170 a-pro mobo, 2x 4gb 2133mhz ram, a tx cooler master cpu cooler /kinda like the hyper 212 evo) in a cooler master n400 case
ps the cpu is being upgraded from current i5-2400 and slow 1333 ddr3 ram
https://linustechtips.com/topic/719472-cpu-question-plz-help/
I would try separating all the components with commas as the post is currently hard to read and may turn people off from posting here.
What is your exact question? Choosing between the two CPUs?
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161803
If you wont be overclocking, ever, then maybe a 6600 (non k)
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161807
for reference - if you're not overclocking go with a H series motherboard.
invest your savings from the motherboard and CPU (6500) into either a better PSU or maybe at a stretch a 1070.
the Coolermaster PSUs are like bombs under any stress.
idk
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161809
its a bundle pack for savings. the cpu, ram and mobo
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161813
if the 6600 (non K) is not an option, then get the 6500. it's still a very good CPU.
try to invest the rest of the money into a 1070 maybe.
if you live in the USA, 1070s can be had for as low as 370USD
Laptop:
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161823
sort of, i wanna go with i5 6500 to save quite abit of money i wonder if i wont overclock 6600k is the performance close to similar and with it out perform my i5 2400 3.1ghz by quite abit since i5 2400 is old as hell?
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161826
i just bought the evga 1060 6gb super clocked, also how would it perform in games like say Bf1 not ultra but like high- medium ish i plan to play a few games but mostly i play World of warcraft, overwatch (not very demanding )
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161834
The performance won't be that large, but some motherboards might be able to keep Turbo Boost engaged across all cores at the same time, allowing the CPU to 3.6GHz which would perform better than a 6600K at stock.
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161837
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130892 this is the mobo, also my i5-2400 is about 6 years old and used quite alot, is my ram slowing down my gaming quite alot cus i only have ddr3 1333 mhz 8gb
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161850
If you buy that motherboard, you will need to buy DDR4 memory.
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9161860
4 hours ago, Markthebeginner said:
but would i see good improvements upgrading from 1333mhz ram to 2133mhz ram?
not really
Laptop:
https://linustechtips.com/topic/719472-cpu-question-plz-help/#findComment-9162866
