Jankiest air restrictor?
Coolslammer
 This fan was making a lot of noise and by putting my hand over the grill it made it much more quite so i figured a piece of paper would do the same thing. The piece of paper is attached with some super putty as well.
PC SPECS: CPU: i5 4460, MOBO: Asrock H97 Anniversary, RAM: G.Skill Ripjaws X 2x8GB, GPU: MSI Gaming R9 390 8GB, CASE: Cooler Master N200, Storage: 1TB WD Blue, PSU: Coasair CX600
Active Folder
You know you're now essentially just choking the fan?
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
Ive put tissue paper on the front of mine at times because dust filters, but then again im aloud to because my case has 5 times more airflow than needed xD
i think your usb ports are jankier
ψ ︿_____︿_ψ_
@SCHISCHKA There is a cover that makes them flush.
@TheRandomness Air still gets through, I tested.
Active Folder
But the fan will spin faster due to less resistance from the air (probably completely wrong explanation, but the same happens to my Titadeon's cooler when I put a piece of plastic over the fan's intake).
USEFUL LINKS:
PSU Tier List F@H stats
wouldn't it have more resistance and spin slower?
blades can stall and push no air when the input velocity is low; https://en.wikipedia.org/wiki/Axial_fan_design#Stalling_effect.2FStall
that might be why your fans speed up
ψ ︿_____︿_ψ_
i see it is the front of case. if your fan is noisy replace it as its bearings are shot
ψ ︿_____︿_ψ_
Well, it went from 4000 RPM to 6780 RPM xD So it probably did that. I didn't know how, but thanks for the wiki page c:
USEFUL LINKS:
On 1/7/2017 at 5:59 PM, Coolslammer said:
-SNIP-
It has to do with the honeycomb mesh, that causes turbulence and excessive noise.
