that's normal. before i had a custom loop i had the same issue. just make sure the pump block is making proper contact with the CPU and you should be fine!
https://linustechtips.com/topic/718740-aio-liquid-coolong/#findComment-9154780
It's normal. I had the same concern with my H115i and so long as you tighten the block all the way done (in a criss-cross pattern of course, few turns at a time) it'll be fine.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/718740-aio-liquid-coolong/#findComment-9154863
