I need advice
10 hours ago, George8987 said:yeah
What resolution are you playing at and what is the refresh rate of your monitor? Model of the monitor will help too. Some people in the thread I linked above resolved their issue by uninstalling the "monitor" drivers, reinstalling them and setting the refresh rate for the monitor to 60hz and limiting the fps in the game to 60hz.
If you are at 1080p or less, make sure your resolution in game and in the OS are the same. If you are over 1080p, your hardware is being taxed and is reaching its limit.
Also for pictures with hardware monitor, close the tab that says voltages at the top and open the one that says utilization under the cpu.
For mafia 3, it just seems to be an insanely taxing game on hardware. According to this benchmark, even a high end x99 chip is only hitting around 34 fps on max settings.
http://wccftech.com/mafia-3-benchmark-nvidia-gtx-1080/
This is usually because of the game engine or very poor optimization. Try the steps I mentioned above, make sure AA and post processing is off and do a custom fan curve for the gpu since 94c is too high imo.
