Choose an IPS Monitor
I know this, but thanks =)
Had a TN 27'' 1080p monitor for a while, switched to 3D 24'' 1080p when upgraded a system, but now want 27 inches back..
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260148
or the 27" version (although, a bit on the expensive side)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824260150
Those are one of the best choices for general-purpose IPS monitors at the moment. As long as you get IPS you're fine; the difference between different variations of IPS is pretty mild. Also don't worry about the response time, it is not a measurement of latency or "delay" before the picture changes, that would be input lag (in which these monitors are remarkably low latency). The "5ms response time or less for gaming" thing is a myth.
