Spec:
Windows 10 64bit
ASUS Z170 PRO GAMING, Socket-1151
MSI GTX 970 Gaming 4G graphics Card
Cooler Master V850 power supply
Intel core i7-6700k processor
Ram 16GB (2x DDR4)
SSD 128 GB
SSD 500 GB
A external drive with 931 GB
Started to get blue screen problems about 2 days ago. I have gotten the message PAGE_FAULT_IN_NONPAGED_AREA, What failed: win32kfull.sys and NTFS.sys. I have also gotten the massage MEMORY_MANAGEMENT. I got a blue screen at least 3 time per day and it's a new thing falling everytime.  I have done a Windows Memory Diagnostics and it found no problems. I have also done this https://gyazo.com/57944f1143d96fe5698bc67b91dd4377.
Any help is appreciated thank you!
https://linustechtips.com/topic/717082-blue-screen-problem/
Might be an overclock issue, try dialing it back a bit and see if it stops. Also think of what you were doing a few days ago, probably has something to do with it...
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/717082-blue-screen-problem/#findComment-9136067
That's it. I have no memory of doing something weird with my pc in the last days
https://linustechtips.com/topic/717082-blue-screen-problem/#findComment-9136088
I've said that before, casually changed some setting without thinking about it and ended up with issues. Still I suggest lowering any OC you've done or run a stress test with ROG realbench for a few hours which should tell you quicker if you have an OC issue
desktop
HTPC
https://linustechtips.com/topic/717082-blue-screen-problem/#findComment-9136162
I can be a bit off here but I haven't done any overclocking on my pc. So I dont think its a overclocking issue.
https://linustechtips.com/topic/717082-blue-screen-problem/#findComment-9136457
it wouldn't hurt to double check, or go into the uefi bios and load optimized defaults. You do have hardware that can OC and it's popping the kind of errors I'm used to seeing on a bad OC.
desktop
HTPC
https://linustechtips.com/topic/717082-blue-screen-problem/#findComment-9137225
