When playing Mad Max I noticed that gpu usage(50% or less), clock speed(1400mhz) and of course temps(36c) are low compared to say Skyrim or TW3. Skyrim,TW3 run about the same, clock(2060mhz) gpu usage(99%) and temps(46C).
I have no complaint with how the game plays, just curious why the game looks and plays so well without my card running as fast as with my other games?
Is Mad Max just well optimized? Or am I leaving some performance on the table?
Gpu: GTX 1070 G1 +98 clock, +475 memory
I5 6600k @ 4.5
And am playing at 1080p.
https://linustechtips.com/topic/716218-mad-max/
I5 6600k @ 4.5
I have the game. It's very well optimized, but it's also not as demanding as those other.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/716218-mad-max/#findComment-9127154
I don't have Skyrim SE but I trust Avalanche much more to put together a well-polished and technically competent PC game than I do Bethesda. I wouldn't be surprised at all to hear Mad Max is easier to run than Skyrim SE. I remember a lot of the launch reviews for Mad Max on PC mentioned how remarkably well it ran while still looking really good.
The Witcher 3 is very demanding. It's not that it's a terribly optimized game, but it's much more ambitious than Mad Max. TW3's foliage and shadow settings in particular seem to hit the GPU hard.
https://linustechtips.com/topic/716218-mad-max/#findComment-9127478
Thanks for the info guys, I am a little new to pc gaming and was just a little surprised with the performance of Mad Max.
I didn't consider the foliage and shadowing, thanks for pointing that out.
https://linustechtips.com/topic/716218-mad-max/#findComment-9128990
I'm not saying foliage and shadows in general are harder to render (although that might be a factor), just that the ones in The Witcher 3 seem to have the biggest impact on the framerate out of all of the game's settings.
https://linustechtips.com/topic/716218-mad-max/#findComment-9130031
Well... They're generally tasking on a GPU.
https://linustechtips.com/topic/716218-mad-max/#findComment-9130460
