Help - HDD data disappearing
Go to solution Solved by Aereldor,
@deXxterlab97, @SCHISCHKA, @The_Dylmyster- I managed to get everything back, and... I'm not sure how. I feel bad marking this as best answer, but I really have no idea what happened or what I did to fix it.
Greetings.
I'm away from home, and brought my external HDD with me. The largest folder in it contains several sets of videos, sorted alphabetically.
When I plugged my HDD into a smart TV, it only displayed four 'panes'- up until 'SP'. However, nothing else was displayed afterwards. I mistakenly assumed that this was because the TV could only display four panes. However, the issue persisted when I plugged it into another Smart TV - with all the folders after 'SP' remaining missing despite the pane not terminating there'. When I plugged it into a computer, I saw that every folder after 'SP' was indeed missing.
This issue has not affected any other folders. My iTunes Library backup folder has not been affected- all folders from '33' to 'ZE' are present, and nothing seems to have disappeared inexplicably, nor are there missing folders after a certain alphabet.
Some of this data will be exceedingly difficult to replace, as I don't have a backup of all of this. Furthermore, I use this hard drive for important transfers, so if this is a sign that the reliability of my external drive has been compromised, I'll have to replace it.
What do you think is wrong? Do you believe there is a way to recover these missing folders? I will not be able to plug it into m own computer until later today.
Regards,
Aereldor.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/715587-help-hdd-data-disappearing/
2 minutes ago, The_Dylmyster said:
This may allow you to recover the files: https://www.piriform.com/recuva
I have used it quite often and it works well! Sorry i can't help with the reliability issue though.
All the missing files show up when I scan for viruses. Huh.
I'll try that next.
1 minute ago, deXxterlab97 said:
Run crystaldiskinfo?
How long habe you had it?
Which HDD? Brand/model?
I don't have any of these tools on this computer.
It's a WD Elements 1TB, and I've never had problems with it.
Also, all the 'missing' files show up when I let Norton scan it for malware. They just won't show up on Windows Explorer or either Smart TV.
@deXxterlab97, @The_Dylmyster- the scan seems to slow significantly when it goes through the missing files. Rather than 20 file s a second, it scans them at 20 seconds per file. What could this mean?
Get it? it's free
Try command prompt way?
Open cmd, type
dir F:\ /ah
Replace F with the drive letter you need.  See if the list contains your files
Also does the total used space on HDD matches with what your drive should have?
Anyway I am going to sleep soon. If you did see your files using cmd method type this to unhide
attrib F:\foldername -r -a -s -h
Keep doing for each missing folders/files
Or the toms solution
go to a cmd prompt type in
chkdsk c: /r
NOTE if the drive is g or whatever than instead of c: type g:
it will take a while wait it out it will fix it all
40 minutes ago, SCHISCHKA said:
i wonder if it has to do with fat vs exfat? the devices youre using might not be 100% compatible with your filesystem
But would that result in them wiping away a ton of my files? The files that couldn't me displayed on the TV are also missing on the computer; which is running 64-bit Windows 10 Home.
The HDD is formatted to NTFS.
@The_Dylmyster- It didn't work. The files show up in the virus scan, but the recovery program can't even find those. No offense to you, but if can't even turn up a trace, then it's a pretty horrible recovery program.
5 minutes ago, The_Dylmyster said:
That's awesome you got everything back!
Thanks. Funnily enough, after all that trouble, I forgot to take it with me and left it at the place I was at. I'll pick it up soon.
