Help?
Go to solution Solved by iRileyx,
Integrated graphics drivers aren't usually an issue,  it's only when removing one graphics card and placing in a different one that you should uninstall the old drivers.
27 minutes ago, CampbellSoup1013 said:
I was told that you have to uninstall old gpu drivers before installing a new gpu and drivers for it. I am getting a gtx 1050 and I was wondering if I have to uninstall the onboard graphics drivers from my processor before installing the gpu.
Follow the guide in my signature, look at the drivers section.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/715006-help/#findComment-9115352
