Swapping gtx 780 to 1080 fail help plz
Solved by App4that,
Yep. Ether using the IGPU or 780 use DDU To boot to safe mode, once there you will see the option to remove drivers and turn off the PC. Do that. Then install the 1080, and download the latest Nvidia driver being careful to get the 64bit version if you have that. Then choose the custom install option and DO NOT install the 3d crap or GeForce experience.
Featured Topics
6
10
rickymohk ·
Posted in General Discussion2 -
Rbakker02 ·
Posted in General Discussion1 -
BaidDSB ·
Posted in General Discussion5 -
2
Mistr J ·
Posted in Troubleshooting3 -
2
5
