how much does a fan effect the performance of a radiator
Solved by 0ld_Chicken,
57 minutes ago, creepybob said:just the gpu
I'd use the xt45 over EK's SE since size doesn't seem to be an issue. Sure the enermax fans aren't as good, but the SE rads are some of the worst performing rads (even among slim rads only).
xt45 with push/pull will be better than the EK SE. The EK SE and Vardars would look better though imo and would handle a single GPU fine
edit: i know its a lot of data, but this site is one of the best for rad info, along with Thermalbench.com
