Is everything wired up correctly?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107164
1 minute ago, JoeyColee said:
Yes, all the cables were checked twice.
Okay, try reinstalling your old cooler and see if that fixes it.
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107207
Just now, JoeyColee said:
I'm kinda wonder why that would work, it was an aftermarket heat sink and fan. Would that really make a difference
You never know until you try ;)
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107229
Darn.. no difderence,my gpu fan though, (750 ti) is in jet mode right now.
Something broke in the process then. I think that it is the motherboard....
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107247
3 minutes ago, JoeyColee said:
Oh no... I really hope not
Just to make sure. Take everything out of the case and boot the system on a cardboard box with the bare essentials that it needs to function and post.
Edited by PCGuy_5960
Autocorrect
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107259
11 minutes ago, PCGuy_5960 said:
Just to make sure. Take everything out of the case and boot the system on a cardboard box with the bear essentials that it needs to function and post.
Darn #2 I don't think the mobo works or something like that.. This really sucks :(
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107319
You haven't plugged in the 24pin connector properly!!!!!!
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107329
-Deleted-
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107367
Fixed that, still nothing
Plug a BIOS speaker in and see what kind of error code it spits out
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107372
Is this right?
Yes, sry. I was clarifying what I said in my previous post. I hadn't gotten the notification of your post yet though.....
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107379
That sadly, is something that I don't have :/
Try:
  1. Unplugging the hard drive
  2. Resetting the CMOS (Take out the battery and all power connectors and wait for a couple of seconds)
  3. Reseating the RAM
If all of that doesn't work then reinstall the CPU as well. And if that doesn't work then (most likely) the motherboard somehow got fried...
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107408
5 minutes ago, PCGuy_5960 said:
Try:
I think my motherboard is a goner :( none of those worked..
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107430
https://linustechtips.com/topic/714247-corsair-h60-help/#findComment-9107433
