As we have established, our max specs for T420, is... 1GB VRAM 4200m, 2860 4c/8t 2.5 - 3.6 GHZ CPU, 16 GB RAM
Now I have the question, where do I get the CPU, i am lowering my price down to a 2670qm though. So... where to get one on the cheap? And is there a performance gap between 2670qm, 2860qm, 2540m, and 2520m?
https://linustechtips.com/topic/713946-mobile-parts/
1 minute ago, Electronics Wizardy said:
Ebay for cpu's. Performance between the different quadcores is within 15%. Its just clock speed difference. The non quad cores are much slower if your using lots of threads.
Could the dual cores (2520 and 2540) still play CS:GO and then turn around and do a voice over?
https://linustechtips.com/topic/713946-mobile-parts/#findComment-9104723
Your pushing it. You probably can with quick sync though or a low quality preset. Your still gpu limited though.
https://linustechtips.com/topic/713946-mobile-parts/#findComment-9104728
Yea, I am talking in a config with a 120 / 240GB SSD (RAID if possible), 8GB RAM, no GPU, and 720p, could either dual core consistently hit 40?
https://linustechtips.com/topic/713946-mobile-parts/#findComment-9104732
You probably could.
What cpu do you currently have? Id get the quads if you can, its not much more.
https://linustechtips.com/topic/713946-mobile-parts/#findComment-9104736
Just now, Electronics Wizardy said:
You probably could.
CURRENTLY, I am not gaming on my laptop (except MC) my current laptop is an HP 15 Notebook with an A6 6310 (1.8 - 2.4GHZ quad core) and 4 GB RAM
https://linustechtips.com/topic/713946-mobile-parts/#findComment-9104740
