for the past 3 weeks my computer act so weird. When i played high load games such as (GTA5, The forest, Cities Skyline, R6S) in 1-10 minutes it suddenly restart itself without any warning at all, just suddenly while i played then it restarted no warning no anything like power shortage.I even barely cant stress test my computer because after a few second it restart itself. My gpu is at normal temperature while playing games 70-73c , it isnt because overheating, all of my drivers are all updated. I think my psu is a problem.... please help me i really confused about this problem,
my rig :
i5 6600
msi b150m night elf
avexir (2x4gb) ddr4
msi gtx 970
corsair vs550 psu
HDD seagate barracuda 1 tb 7200 rpm
https://linustechtips.com/topic/713913-is-this-a-psu-problem/
1 minute ago, DarkBLiz said:
for the past 3 weeks my computer act so weird. When i played high load games such as (GTA5, The forest, Cities Skyline, R6S) in 1-10 minutes it suddenly restart itself without any warning at all, just suddenly while i played then it restarted no warning no anything like power shortage. My gpu is at normal temperature while playing games 70-73c , it isnt because overheating, all of my drivers are all updated. I think my psu is a problem.... please help me i really confused about this problem,
my rig :
i5 6600
msi b150m night elf
avexir (2x4gb) ddr4
msi gtx 970
corsair vs550 psu
Have you checked your cpu temps because that could also be the problem?
https://linustechtips.com/topic/713913-is-this-a-psu-problem/#findComment-9104345
5 minutes ago, DarkBLiz said:
No it isnt my cpu temps at 40-50 at idle 80-85 at max load
Well 85°C is hot for locked chip mate.
It's not the reason why your PC is turning off on it's own, but 85°C is not okay temperature for i5 6600 (non K version) while gmaing.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/713913-is-this-a-psu-problem/#findComment-9104435
Ups sorry my bad it 40 at idle and 58-62 at high load
https://linustechtips.com/topic/713913-is-this-a-psu-problem/#findComment-9104519
Ah okay, those are better numbers.
WD My Cloud 4TB
https://linustechtips.com/topic/713913-is-this-a-psu-problem/#findComment-9104573
You can snag a psu tester on Amazon. Grab a decent one ($35 or so). Trust me, it does wonders with testing out the power supplies. It just saved me major headaches, as my corsair hx850 just started dying on me after 6 years if heavy use.
Thermaltake Dr. Power II Automated Power Supply Tester:
https://www.amazon.com/dp/B005F778JO/ref=cm_sw_r_cp_apa_XjrzybNRP69YM
https://linustechtips.com/topic/713913-is-this-a-psu-problem/#findComment-9105656
