I'm Looking to build my first PC for the tower itself I want something as small (thin and tall is better than boxy) as possible nothing that would draw attention to itself. I plan on running two monitors (gaming/auxiliary). I've never been concerned with maxing out graphical settings, but my current computer (4 yr old laptop) crumbles during intense moments when running League of Legends in low quality with sound disabled. I don't plan on using a lot of storage because I'm not one fear re downloading things and I don't store anything I wouldn't mind deleting in a years time. Id like to keep my budget under $1,000 USD with the purchase of the two monitors included. But I'm a firm believer I can easily get what i want for 800-900
PCPartPicker part list: https://pcpartpicker.com/list/Htwy8K
Price breakdown by merchant: https://pcpartpicker.com/list/Htwy8K/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($109.99 @ SuperBiiz)
Motherboard: MSI B150M PRO-VDH Micro ATX LGA1151 Motherboard  ($66.99 @ SuperBiiz)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($41.98 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Best Buy)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  ($174.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mini Tower Case  ($40.99 @ NCIX US)
Power Supply: Antec EarthWatts Green 380W 80+ Bronze Certified ATX Power Supply  ($42.89 @ OutletPC)
Total: $542.81
Generated by PCPartPicker 2016-12-28 21:56 EST-0500
A lot of these parts seem to be on the "bang for the buck" list in other budget builds and I'm not confident in my Graphics Card and Processor choices as it feels arguable I could go for a better processor (6400) and perhaps a worse graphics card(???). and am even considering skimping out a bit on the SSD and dropping it to a ~100gb version.
The Case seems to be tried and true, I'm not particularly happy with the form factor but it seems like it might not be possible to get the thinness I want because of the way gpus slot into mobos.
When it comes to monitors I really don't know what to do, Initially they'll need to be set up in a rather tight space where 2x23" monitors will not fit well (I won't be able to get a good measurement for about another week) When it goes down to IPS refresh rate LED other similar specs I'm inclined to say I don't care but really I've never experienced it. I would like included speakers though. As for a two monitor setup I don't know how tasking on my heart it would be to have a larger monitor for my primary viewing screen then a smaller one for my auxiliary screen.
https://linustechtips.com/topic/713836-first-build/
14 minutes ago, deXxterlab97 said:
Id try spend a bit more on 1060 3gb or better 480 4gb. 470 is not bang for the buck when a 480 or 1060 is clearly better and for 20-30 dolalrs more
i don't know about that psu would be enough for you. maybe @STRMfrmXMN can tell?
PSU is fine for any of those GPUs and a 470 is actually pretty OK value for money.
https://linustechtips.com/topic/713836-first-build/#findComment-9103889
