new build, i got the i5-6600k overclocked to 4.2 ghz with the asus z170a auto-overclock 20% thing in bios, i have the 212 evo as cooler and arctic silver 5 thermal paste.
i see my max load temps are about 60 degree celsius and my idle temps are around 26 celsius, is this normal? what is the max threshold for my processor on msi-afterburner?
ambiant temps are in the 20 celsius in my room, i also get my gpu which is the xfx gtr to never go above 65 celsius in base clock with 2250 rpm fan speed set as max for optimized silence.
https://linustechtips.com/topic/713692-are-my-temps-normal/
That sounds nice and healthy!
As a rule of thumb, you should only really get uncomfortable beyond 80 or 85 celsius under sustained load.
Why don't you push your chip further?
Sig under construction.
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102207
That is 100% fine. For CPU temps during a stress test you want it to be around 75c at max. This is the goal you should shoot for.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102210
As stated here it is :)http://www.tomshardware.com/forum/285525-28-degrees-celsius
CPU: i7-6700K | Motherboard: MSI Z170A Krait Gaming 3X | RAM: Corsair Vengeance LPX 8GB DDR4-2666 Memory
Solid State Drives: Two PNY 120GB 2.5" Solid State Drives | GPU: EVGA GeForce GTX 1070 SC GAMING ACX 3.0 Black Edition
PSU: Thermaltake Smart 650W 80+ Bronze Certified ATX Power Supply | Case: Thermaltake Core V71 ATX Full Tower Case.
PCPartPicker
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102214
looks good to me. 26c idle is fantastic, mine idles at 34c at 4.2ghz xD
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102215
5 minutes ago, Tedster said:
I idle at 50% load, so sometimes around 50 or 60C (:
how. thats a bit high for idle lol.
Old Rig
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102257
My 4670k is a really terrible overclocker but I really want 4.2GHz...long story short, I settled on running it at 1.4V. I often have a couple hundred chrome tabs open as well as a couple programs that just eat CPU for no reason every now and then *coughs* iTunes Spotify *sputters*...
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102273
thanks for the replies guys, also to answer tedster, i don't OC my chip further because i am new to overclocking, this is my frrst build ever and i don't yet quite feel comfortable pushing this new shiny stuff, the auto 20% overclock on the asus z170a is fine i think, i don't think it increases the voltage on the cpu, which stays around 1.25V max in cpu-z, all while pushing me above the 4ghz. my ram is trident z 3200 mhz and it does 3300mhz on xmp 3200 profile somehow too, i dont get why but wathever xD
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102348
Just now, Howitz said:
thanks for the replies guys, also to answer tedster, i don't OC my chip further because i am new to overclocking, this is my frist build ever and i don't yet quite feel comfortable pushing this new shiny stuff, the auto 20% overclock on the asus z170a is fine i think, i don't think it increases the voltage on the cpu, which stays around 1.25V in cpu-z, all while pushing me above the 4ghz.
Alright!
Just to be sure, run yourself an FPU-only test in AIDA64 and just make sure that the chip doesn't go to any ridiculous voltages.
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102356
2 minutes ago, Tedster said:
Alright!
do you have a link for aida64? is this a free software? i only seems to find stuff i gotta purchase xD
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102365
6 minutes ago, deXxterlab97 said:
unfortunately  you have to pay. iirc u have free tiral?
It's paid-for but you can download a thirty day free trial.
Have a look here.
https://www.aida64.com/downloads
https://linustechtips.com/topic/713692-are-my-temps-normal/#findComment-9102416
