CPU
Intel Core i7-6850K ?
Intel Core i7-6800K?
Intel Core I7-6700K Processor?
Other parts
Asus Z170-PREMIUM Intel Socket LGA 1151 HDMI DisplayPort 8-Channel HD Audio ATX Motherboard
Corsair Vengeance LPX 16GB DDR4 (2 x 8GB) PC4-22400 3000MHz C15 Memory Kit
Hi. I am building a new pc. Can't decide which cpu shall I go for.  I got a psu, a case, a graphic card and monitors already so I don't need a new one.
I can't decide should I go for 6850k or 6700k. The computer are used for rendering videos, running multiple VMs, and sometime games. I am looking into long term use. Budget is unlimited.
Please help me out!
https://linustechtips.com/topic/713455-help-which-cpu-should-i-go-for/
for rendering get a 6800k instead. the extra core will help.
Just now, edmundhei said:
if I use 6800k , do i have to use a x99 motherboard?
yes. you need to use an lga 2011-3 motherboard.
1 minute ago, edmundhei said:
any good suggestion?
this one looks pretty good.
https://pcpartpicker.com/product/FGPzK8/asrock-x99-taichi-atx-lga2011-3-motherboard-x99-taichi
