Thin Fans
Go to solution Solved by SeeFights,
3 hours ago, WoodenMarker said:
Oh, that makes more sense.
As mentioned already, XtraFlos should work. If you can measure to see that you have enough clearance, 20mm Yate Loons may also work.
i bought some 12mm fans, they are okay and i only gain like 5oc in every game, thanks for the help though
I got a H100i for crimbo and we fitted it in the case and the radiator + both fans don't actualy fit. One fan pushes against the cpu power cable and the other fan pushes on the ram slots but not the ram, not a problem but can cause problems. I can't fit them externally before you say. Just looking for thin and good fans.
https://linustechtips.com/topic/712575-thin-fans/
Is there someplace else in the case the radiator could be mounted, like in the front as an intake? I'm not familiar with any 15mm fans that provide great static pressure.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091028
they dont need to provide great static pressure just enough and no it cant be put at the front sadly
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091037
5 minutes ago, APasz said:
At least you waited 3 hours to post again.
Anyway a quick search on your favourite online store will provide. You're looking for by 12mm. Scythe are the main guys who make them.
thank you and yeah i waited 3 hours and thought lets just post again
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091078
There are no amazing thin high static pressure fans really out there but the best ones as of currently are theses from cooler master:
 http://www.coolermaster.com/cooling/case-fan/xtraflo-120-slim/
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091151
yeahhhh, i live in the UK where would i find them>?
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091158
If you don't have them available looking at some alternatives the silverstone or gelid ones would be the next option
https://www.overclockers.co.uk/silverstone-sst-fn123-fn-series-fan-1215-white-black-fg-051-sv.html
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091189
7 minutes ago, APasz said:
It's only a difference of 3mm so it'll be good.
i only ask cause i have no idea about fans, just that they turn and are gud
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091201
Where are you trying to fit the rad?
https://linustechtips.com/topic/712575-thin-fans/#findComment-9091845
top of the case, the case is the aerocool 500. The Mobo is too close to the top resulting in the CPU power cable to be pushed on when a fan is installed along with a radiator and the DIMM slots are pushed on when a fan is installed. Before you say install the rad at the front i cant.
https://linustechtips.com/topic/712575-thin-fans/#findComment-9100069
Isn't that just a matter of cable management? A zip tie or bracing the cable between the two corner flanges of the fan should solve that.
https://linustechtips.com/topic/712575-thin-fans/#findComment-9101801
no it is onistly that the power cable is too high up and a fan is pushing on it, no way too fix it.
https://linustechtips.com/topic/712575-thin-fans/#findComment-9101819
https://linustechtips.com/topic/712575-thin-fans/#findComment-9101835
https://linustechtips.com/topic/712575-thin-fans/#findComment-9102978
