USB 3 Type C Front Panel Suggestions?
I want to add a front panel USB C to my computer (5.25" slot).  Does anyone have a suggestion?  I've seen some that use a USB 3 connector to the motherboard, but my mobo only has one USB 3 input, and it's currently used for the two USB 3 Type A ports on my case.  Is there any way to add a front panel USB C other than the USB 3 connector on the mobo?  I know there are PCIe cards, but I would really like the USB C ports to be on the front.  Any suggestions would be much appreciated!
https://linustechtips.com/topic/712533-usb-3-type-c-front-panel-suggestions/
You could get a 5.25" bay that has both USB Type C and USB type A ports.
The only issue with this is that this would make the case USB ports not work.
I had an account called Joegeddon active since April 20th 2015
Desktop
AMD Ryzen 5 2600 | XFX RADEON RX580 8GB XXX | 16GB 3000MHz DDR4 | Thermaltake Versa H22 | Corsair RM550x PSU | MSI AM4 B450M-A PRO Motherboard
1TB 7200RPM HDD | 500GB 7200RPM HDD | 500GB M.2 WD BLUE SSD
Laptop - Asus UX303UA
Intel i7 6500U | Intel 530 Graphics | 12GB 1600MHz DDR3 | 256GB SATA 3 SSD
3 minutes ago, APasz said:
You can get pci cards that have either or both ports and headers.
AH! I hadn't even thought of that.  Any suggestions for PCIe card with USB 3 header? Also, still looking for suggestions on a 5.25" front panel USB Type C.
