Hello everyone !
I am thinking to buy something like i7 6800k.
Since his stock speed is 3.4 ghz, I would like to know how far should I go with overclocking.
How much speed should I go ? I was thinking to push it somewhere to 4.0. Is there need to go higher or it just not worth it, and also what cooling should I use with that ?
Anyone having experience with speed/voltage/colling ?
thanks.
https://linustechtips.com/topic/712042-water-or-liquid-colling/
Isn't water/liquid cooling the same thing? Anyways, i7s tend to get pretty hot so I don't think fans will cut it and for overclocking, it all depends on the cpu, some might go higher than others, you'll just need to experiment.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9086563
A friend of mine IRL has a 6800K overclocked to 4.2 Ghz at 1.25V. Past 1.3V, the chip ran very hot even with his cooler hard at work. He's currently using the Corsair H100i GTX. Needless to say, 1.3V was unstable.
I recommend liquid cooling for a CPU like the 6800K, unless you want a big, bulky air cooler. Water is usually the coolant of choice, as its heat capacity is superior to most other liquids.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9086587
Water cooling is a type of liquid cooling, but not all liquid cooling is water. Technically, some custom loops don't use water but use different coolants that are based on water but have quite a lot of other things inside that you wouldn't want to drink or use otherwise. Liquid nitrogen cooling is used for the most EXTREME overclockers in the world (which is one of the reasons I believe they got a 6-core AMD chip to something like 8 gigahertz). Also, mineral oil cooling could be considered liquid cooling.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9086622
yeah, thanks for the clarification. I just hear water cooling and liquid cooling used together a lot but I get you. :)
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9086628
29 minutes ago, DarkScott said:
Hello everyone !
thanks.
I'd suggest getting something like an H110i or H115. Also, the new NZXT X62 should be a good cooler. I'd recommend water cooling over air cooling if you are looking for the best overclocking ability you can get, however personally I prefer beefy air coolers like the Noctua NH-D15 because of reliability and I like the look personally.
iPhone 6
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9086629
Yes i my mistake. I was about to ask air or liquid colling haha.
Alright, thanks for suggestion
Alright thanks.
Maybe some case recommendations ?
Something that looks good but its not expensive. I would not spend more than $80 for it.
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9093700
Unstable at 1,3V because of temperature?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9093718
You don't need liquid cooling for a 6800k lol! A top end air cooler from Noctua or Cryorig would be more than enough to keep it cool, even overclocked! Such a load of nonsense gets peddled around regards water cooling, but just look at the reviews! There's a big aesthetic advantage sure, but the performance numbers clearly show a very small gap. Some AIOs are even worse than air. If you really want the best temps, you have to go custom... but that is an expensive route and certainly not necessary to get great performance from the CPU.
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9094836
Alright thanks.
For cases under/around $80, I'd suggest the following
- Phanteks P400S (sound dampening, big window, built in RGB)
- FD Define S (great watercooling support, clean brushed aluminum look)
- NZXT S340 Elite (tempered glass, good for VR, PSU shroud)
iPhone 6
https://linustechtips.com/topic/712042-water-or-liquid-colling/#findComment-9113049
