Hi,
I have about 1000 $US for my first PC.
The parts I was thinking about are :
CPU: Intel Core i5-6500
Motherboard: MSI B150 GAMING M3
GPU: Gigabyte GeForce GTX 1060 Windforce OC 6GB
Storage: SSD Crucial MX300 275GB
Memory: G.Skill Ripjaws V, DDR4, 16GB (8GBx2), 2400MHz
Power Supply: XFX TS 550W
Case: Corsair Graphite 230T
I don't need anything more in terms of storage as for now. Is it worth paying some more $ for intel i5-6600K and some z170 motherboard for the ability to OC later on, considering that I cannot afford any better GPU ?
https://linustechtips.com/topic/711855-first-pc-for-about-1000us/
2 minutes ago, Pandaoo said:
Hi,
You could spend less on the ram (maybe 2 4 gb or some cheaper 16 gb ram) and get like a sapphire rx 480 insted of that weak 1060.
5 minutes ago, Pandaoo said:
Hi,
Or just wait for zen.  Couple more months maybe, then you could get cheaper i7s or just get a zen cpu
Agreed, find lowest DDR4 speed available(must be equal or greater than 1600 MHz), and only 8 gigs. As well, for this kind of build, considering that i5s aren't for workstations style use, I would switch to AMD 4 CPU and BEEF up the GPU to  a 1070, maybe. I'm currently on a hexa-core AMD fx-6350, and it works gorgeously. Pls review this suggestion.
CPU: Intel Xeon E3-1230 V5 3.4GHz Quad-Core Processor  ($251.99 @ SuperBiiz)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($19.99 @ Newegg)
Motherboard: ASRock E3V5 WS ATX LGA1151 Motherboard  ($107.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($64.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($383.99 @ NCIX US)
Case: DIYPC J180-W ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply  ($49.99 @ B&H)
Total: $993.91
Generated by PCPartPicker 2016-12-25 19:27 EST-0500
