Someone here on the forums has recently helped me find a PC that I have been looking for, and I want to upgrade it with a 1050 ti (or something that doesn't require an external power connector) and a powerful Core 2 Quad. The last thing I want to upgrade it the RAM, but I don't know what type it accepts, DDR3 or DDR2. Can someone help me figure out support for these upgrades? The PC is a Dell Optiplex 755, in the "desktop" form factor. Thanks, merry Christmas :)
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/711693-will-it-work/
all C2Qs use DDR2, the LGA 755 socket can only use DDR2 or DDR1 in some rare cases
Builds:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083611
2 hours ago, frozeNNN said:
Install CPU-Z and see what RAM is uses
I don't have the system yet, but I'm gonna get it soon.
SPECS:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083677
It can use DDR3 aswell
But will the motherboard work with a Q6600?
SPECS:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083718
iv looked around quite a bit on used motherboards and i have never seen a LGA 775 motherboard with DDR3, please show me some proof of this because iv never seen a C2Q using DDR3
Builds:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083720
its using DDR2 from what i can find
Builds:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083722
SPECS:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083723
cool thanks, anyway your compuer isnt using DDR3 from what i have found atleast but if you can, go into taskmanager and then under the preformace tab on the RAM menue it should say a speed, if thats 800MHz or lower its DDR2 and if its above 1000MHz it should be DDR3 assuming its running at stock speeds
Builds:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9083728
3 hours ago, frozeNNN said:
Dude i don't see anywhere that you mentioned motherboard's name so how can i know?
How am I supposed to know the motherboard's name? It's a prebuilt Dell....
SPECS:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9089769
As i said,install cpu-z and see.
And I replied to that, I don't have the computer, it's just an Ebay listing and I want to know what parts to buy to upgrade it.
SPECS:
https://linustechtips.com/topic/711693-will-it-work/#findComment-9090122
