Would a core 2 duo work fine with a 2gb rx460 sick of buying dead used core 2 quads
https://linustechtips.com/topic/711541-would-a-e8400-work-with-rx460/
2 minutes ago, Biggerboot said:
Core 2's are kinda showing their age now.  It would work just fine, but I'd save up for a different board or go with something a bit more the CPUs age (used 660 or 7850).
I already own the 460 and the 775 mobo with 8gb of ram
At that point, you may as well, but there will be some bottlenecking present, depending on the game and resolution.
USEFUL LINKS:
PSU Tier List F@H stats
3 minutes ago, Jack the Stripper said:
yeah it can, but what games you play?
csgo,gta5 (i know that will run bad) and doom
CSGO is the only one that will definitely run fine.  Doom maybe you'll get 30fps all low if you're lucky.  Same with GTA V.
Check r/ hardwareswap if you're in the US.  They'll practically give you a core 2.
this is my guest pc not the end of the world
Understood, I saw your sig.  I'm speaking in terms of putting a GPU inside.  It would've still been pretty good for a (what was considered) mid range GPU a couple of years ago.
