Problems with the Corsair K70 LUX RGB after CUE update: 2.8.7
Solved by Iotaaa,
Quick an easy fix I found to this:
You need to perform a Soft Restart
1. Unplug the keyboard from the PC.
2. Press and hold ESC
3. Plug the keyboard back into the PC (Whilst still holding ESC)
4. Hold the ESC key for 10 seconds then release.
The keyboard should flicker and should now work
Featured Topics
4
5
7
kodokuj ·
Posted in Graphics Cards2 -
Repoball ·
Posted in Troubleshooting3 -
OybeX3D ·
Posted in Operating Systems0
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
