Hello. I have recently been building a computer and I have an Intel i7 5820k, MSI X99a SLI Plus Motherboard, and when I insert the Windows 10 Pro disk into the computer, it just says
Reboot and Select proper Boot Device
or Insert Boot Media in selected Boot device and press a key.
I can get into the BIOS fine, and I made sure to put it at first boot priority. I checked with 2 different optical drives and 2 identical Windows 10 Pro DVDs.
Please Help!!!!!!
https://linustechtips.com/topic/711105-please-help/
Your certain your booting the optical drive, that exact error would show if you booted the hard disk.
you want all optical drives/cd drives BEFORE all hard drives.
Also if your pc shows a "boot menu" or "select boot device" by pressing f3 or whatever, make sure you press it
https://linustechtips.com/topic/711105-please-help/#findComment-9077730
I tried that and it still gave me the message.
https://linustechtips.com/topic/711105-please-help/#findComment-9077760
did you hit a key?
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/711105-please-help/#findComment-9077791
