 Hello, I'm planning to make a portable PC, please look it over and point out any changes that you'd recommend.
 My budget is around 1000USD I'm currently living in Hungary so I was planning on probably buying everything off Amazon.
  • Plan on using it for gaming, programming etc,
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H75 54.0 CFM Liquid CPU Cooler
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory
Storage: Crucial MX300 525GB M.2-2280 Solid State Drive
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Sapphire Radeon RX 480 4GB NITRO+ 4G Video Card
Case: Cooler Master Elite 130 Mini ITX Tower Case
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Monitor: Asus VS247H-P 23.6" 1920x1080 Monitor
This comes to around  $1200 on pc part picker.
https://linustechtips.com/topic/710711-first-build-mini-itx-help/
do you plan on overclocking.  if not i would swap the cooler for an air cooler and maybe use the money you saved to get a i7 instead since it will help alot with programing and other heavily threaded applications.
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
Definitely no to the WD Black drive. They run hot, which is bad in a cramped little ITX case like the Elite 130, they're loud, and the only time you notice the extra speed is if you're using a WD Blue drive on the same PC at the same time. Otherwise, you'd never know.
Just about any 1TB hard drive by WD, Seagate, Hitachi or Toshiba is fine these days, and I'd highly recommend something like a WD Blue, Seagate Barracuda or Hitachi Deskstar/Ultrastar over a WD Black. It's just a poor value and isn't really worth the higher price.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
Alright let's make the build cheaper and more portable.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($207.45 @ Amazon)
Motherboard: MSI H110I PRO AC Mini ITX LGA1151 Motherboard  ($85.18 @ Amazon)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR4-2400 Memory  ($49.01 @ Amazon)
Storage: Crucial MX300 525GB 2.5" Solid State Drive  ($136.18 @ Amazon)
Video Card: XFX Radeon RX 480 4GB RS Video Card  ($214.64 @ Amazon)
Case: Silverstone RVZ02B HTPC Case  ($89.25 @ Amazon)
Power Supply: Corsair SF 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($89.92 @ Amazon)
Monitor: ViewSonic VX2457-MHD 23.6" 1920x1080 60Hz Monitor  ($156.01 @ Amazon)
Total: $1027.64
Generated by PCPartPicker 2016-12-22 21:51 EST-0500
500GB should be enough to last a while, you can add a hard drive later.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
The Elite 130 can't take much of an air cooler at all. Certainly not one that would outperform a 120mm AIO.
I was planning to do some overclocking, but I think if I could upgrade to an i7 it would be worth it.
what low profile air cooler would you recommend, since the Elite 130 doesn't have that much space for a standard air cooler.
maybe a Silverstone NT06-P or even a cooler master gemini are good but when you bring over clocking into the equation it becomes a bit more difficult
Alright, thanks you make a good point, I'd definitely change that.
Total: $1027.64
I do like Silverstone case the fact that you can practically carry it in a laptop bag.
if I don't get the 6600K I wouldn't need AIO cooler.
However I would like 16 gigs for all those chrome tabs :P
Hmm, how can we fit 16GB RAM?
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($88.18 @ Amazon)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($79.00 @ Amazon)
Total: $1009.63
Generated by PCPartPicker 2016-12-22 22:11 EST-0500
Computer Specs:
With the small case I always knew that overclocking might not be on that table.
Not just that the additional cost of an OC mini-ITX motherboard is not small
Computer Specs:
Total: $1009.63
That seems pretty good, I can always upgrade my storage as time goes on,
I think because I was set on overclocking I made some of the wrong choices, but I like the looks of this build.
I'd suggest going for a dual-drive setup so you'll have the best of both worlds; speed and mass storage. I also went for a faster GTX 1060 6GB. I also got a slightly smaller, 23" 1080p IPS monitor. :)
Storage: ADATA Premier SP550 120GB 2.5" Solid State Drive  ($51.18 @ Amazon)
Storage: Hitachi Ultrastar 500GB 3.5" 7200RPM Internal Hard Drive  ($33.50 @ Amazon)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($264.99 @ Amazon)
Monitor: AOC i2267Fw 22.0" 1920x1080 60Hz Monitor  ($115.13 @ Amazon)
Total: $985.61
Generated by PCPartPicker 2016-12-22 22:18 EST-0500
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
@DilonCSK Or if you'd prefer a 16GB (2x 8GB) RAM combo, here you go:
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory  ($88.99 @ Amazon)
Total: $1025.59
Generated by PCPartPicker 2016-12-22 22:23 EST-0500
My Daily Driver:
Total: $985.61
That's a really good price for an IPS monitor, I'll definitely have a look.
Honestly the performance difference is not noticeable, it's not like going from 1050 Ti to 470, or from 1060 to 1070. That's why I keep giving people the $220 part and not the $260 one.
There's also freesync which makes frames smoother on top.
Computer Specs:
Doesn't FreeSync only work when frames are below the monitor's refresh rate? Just to confirm. :)
My Daily Driver:
