Hey guys I just recently for my Watercooling setup and I'm trying to overclock my FX 8300 chip but after a few Attempts that seemed promising my PC crashed and after I rebooted everything became underclocked slightly Ram, CPU, HT speed. by like 10mhz and now it crashes frequently and I'm not sure if its data corruption or what.
https://linustechtips.com/topic/710707-fx-8300-overclocking-issues/
Did you stress test your overclock? You always stress test your overclock. And if it's unstable, push more voltage through it.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Thats what I was attempting to do when it crashed like an hour in.
how much voltage
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Time to increase voltage then. Also keep an eye on every other setting that affects system stability, like RAM speeds and such.
Computer Specs:
1 minute ago, Thatguywiththetoasterpc said:
1.28v
Considering you're on a custom loop you can probably do 1.4V no problem
Computer Specs:
yeah but every thing is underclocked still like 3.29ghz instead of 3.3ghz and it's the same even when I try to increase the OC this also effects ram and the HT link speed.
I have a shot mobo that has a 4to1 vrm so it fucks up when I try to pass 1.33v
then don't oc
Ah you're stuck with low clocks then. Lower clockspeeds until you pass the 8 hour stress test
Computer Specs:
yeah but im dtill trying to fix the main problem that everything is running slower than it should at stock speeds in trying to fix that first.
Step one whenever you fuck everything: load optimized defaults in your motherboard (or clear your CMOS using a button or jumper)
Computer Specs:
alright I already tried to reset to defaults so I'll try that next.
