I just spilled stuff on my computer not 3 seconds ago, I dismantled the entire thing and cleaned off the drops on the mother board and cpu with a towl. Is it ok to use a towl? Also my computer is cover in dust and when the liquid fell on the cpu heat sink it got all gunked up, I don't have any compressed air, non static cloths, or thermal paste. What should I do?
https://linustechtips.com/topic/710672-need-help-asap/
Put the stuff in rice. For the stuff that's too big, leave it out to dry for a long time.
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072657
it wasnt directly on it more like back splash from hitting my wall idk if it shorted i just puled everything out of it, and idk if i have rice GG?
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072662
I'm assuming this is a desktop?
In any case, keep it off, make sure there is no power at all, and you can basically just leave it out to dry. You'll probably want to dry off metallic components with a towel (yes, a towel's fine, so is paper towel, tissue, and microfiber), just to avoid corrosion.
And for the love of god clean out that dust after it's dry.
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072669
Better safe than sorry. If you don't have rice, dry off as much water as you can with paper towels and such, and leave everything to dry for awhile. And by awhile, I mean like a week min in a warm place.
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072670
I got about 20 bucks and I would have to check on that alcohol stuff, but i used a towl to clean off all the droplets and whipe the cpu, I sill have my heat sing full of a mix of soda & dust in between the fins and i cant submerge it b/c I haven't got any thermal paste
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072678
1 minute ago, ANCIENTSTIGG said:
Wait until you can go buy some paste and board cleaner. DO NOT use synthetic materials anywhere near the board or cpu. Wait until you can go buy some paste and board cleaner. DO NOT use synthetic materials anywhere near the board or cpu.
literally dabbed it with the corners of a towl
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072681
literally, the moment i hit my cup i flip my pc over to avoid liquids hitting the mobo, then diamante everything on my table, everything back to square 1
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072696
been a lot of posts like this recently, I don't know how people manage it. Anyway, do as others have said already regarding letting it dry. You did the right thing switching it off asap. Chances are that if YOU switched it off and it didn't do it itself - I guess it will be ok. Just be patient regards letting it dry out, like 1 - 2 days
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072698
i may have not wither i pulled it from he wall or something or fomr the computer but i didnt really have time to look at what i was doing just took it appart on my kitchen able
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072704
i think it need to be cleaned better it was soda and not water that spileld on it
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9072709
How do I fix this mess?
psu extreme dust
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9073810
i use a new paint brush and compressed air, you can buy tins of it in a lot of places
Ryzen Ram Guide
https://linustechtips.com/topic/710672-need-help-asap/#findComment-9075259
