I have an old computer (I mean really old, IDE old, which I got cheap) my problem with it is when ever I plug it into a VGA monitor and turn it on it says that it's not supported, any way to fix this or am I fucked?
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
https://linustechtips.com/topic/710641-vga-issues/
1 minute ago, SCGazelle said:
What resolution is the monitor, and what are the graphics of that computer? It might not support that resolution.
not sure
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072338
6 minutes ago, SCGazelle said:
what is the computer model?
it's an old one, uuuum
Viglen
The specs are:
Intel Celeron 2.4GHZ
2GB DDR RAM
DVD Drive
160GB HDD
Windows 7 PRO
that's all I can see and find out about it without it being turned off
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072359
Your VGA isn't supporting the refresh rate of that monitor or vice versa. Go into safemode and start with a low resolution or VGA mode only. Set it to the lowest hertz and try again. Your other 2 options, is to try a different monitor or a different video card.
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072364
can't as the problem appears as the BIOS screen appears so I can't do that
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072371
Did you try a different monitor, video card, and cable?
no PCI-E slots so can't get any of my video cards in, and an error message appears on the screen and the cable works with other PCs, and I haven't tried any other screens as I will need to put a large amount of effort into getting it, and I will need it back where it is at some point, probably tomorrow so it's too much effort to try it incase it doesn't work, as it's in an awkward position due to it needing a special power cable which is behind my ATX Server pile
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072395
Sometimes that monitor not supported error doesn't mean it's not supported. It could also mean your system is not posting.
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072404
that's my worry as the case is bend and I am wondering if it's been damaged and if it's still working encase it's been damaged in transit
https://linustechtips.com/topic/710641-vga-issues/#findComment-9072413
