I am currently running my i5-6600k @ 4.5 Ghz with a lepa aquachanger 240. I ran Aida 64 on my CPU for 30min and throughout the entire test the temps stayed around the low 50s (Celsius) on the CPU and the cores were all over the 40s and 50s area. Is it weird the i am getting good temps with an overclocked CPU, and an okay/good cooler.
https://linustechtips.com/topic/710539-50c-max-load/
You forgot to mention one tiny detail: the voltage. That plays a huge factor, yet you didn't mention what your CPU was running at.
Regardless, such low temps are somewhat expected, given that you aren't stressing your CPU very hard.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/710539-50c-max-load/#findComment-9071152
as mentioned, voltage plays a huge factor in the amount of heat that is produced. so yeah, if you left the voltage at stock these temps are about to be expected.
https://linustechtips.com/topic/710539-50c-max-load/#findComment-9071171
14 hours ago, AYM123 said:
the voltage is set to 1.33v and is currently at 1.336v
Kinda high temps for the voltage, but still not TOO surprising, given that it's AIDA.
https://linustechtips.com/topic/710539-50c-max-load/#findComment-9074360
