Replacement stand for a TV
Solved by W-L,
2 minutes ago, Dubesta11 said:
That's what I was thinking, but its a lot more money than the first type of stand I posted.
I would say go for the second it looks much sturdier, as for the bolts on the original they most likely are metric sized you can get a few within that size range and try them out.
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
16
1
