Hello everyone.
So i am new to this Forum and I am in dire need of help.
So I've had my PC I've personally build myself for about 1-1/2 years and I've been loving it
But some times when i use my PC there are a lot of freezing that happens which freezes and stays frozen until you hard reset it or power it off
This mainly happens when I play my video games, also streaming. I have an RGB keyboard which rotates around in a rainbow pattern and when my computer freezes
that also freezes, Its like my whole PC just freezes up and there's nothing I can do about it. I have uninstalled my CPU driver and reinstalled it which helped for about a couple months
but it had just recently reoccurred again. I have checked if I had any malware, and i'm pretty sure i don't because I ran a lot of security tests with AVAST. I've cleaned out my whole PC
such as all the unnecessary files, and all of the junk that's in my PC. Still freezes. It is very frustrating because all of my temps on my pc are very stable and they don't overheat at all. I dont think its a ram issue
im not sure if its a BIOS issue
All of my software and drivers are all up to date.
i just hope i can get some help before I format my HDD and My SSD as my final hope.
I will list my specs if anyone could help me out it would be fantastic.
Corsair Hydro Series H100i GTX High Performance Liquid CPU Cooler CW-9060021-WW
Corsair Gaming STRAFE RGB Mechanical Gaming Keyboard, Backlit Multicolor LED, Cherry MX RED (CH-9000227-NA)
ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Corsair CC600TWM-WHT Special Edition Graphite Series 600T Mid Tower Gaming Computer Case - White
Sapphire R9 290X 4GB GDDR5 DUAL DVI-D/HDMI/DP TRI-X OC Version PCI-Express Graphics Card 11226-00-40G
AMD Octa-core FX-9590 4.7GHz Desktop Black Edition 8 Socket AM3+ FD9590FHHKBOF
HGST Travelstar 7K1000 2.5-Inch 1TB 7200 RPM SATA III 32MB Cache Internal Hard Drive 0J22423
Corsair Dominator Platinum Series 32GB (4 x 8GB) DDR3 DRAM 2400MHz PC3 19200 C11 Memory Kit
Corsair AXi Series, AX1200i, 1200 Watt (1200W), Fully Modular Digital Power Supply, 80+ Platinum Certified
Samsung 850 EVO 250GB 2.5-Inch SATA III Internal SSD (MZ-75E250B/AM)
https://linustechtips.com/topic/709793-computer-freezing-problem/
Welcome to the forums!
List your PC specs and is the system overclocked?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
3 minutes ago, Bigpanda said:
Thank you! and the system is not overclocked no.
Open Windows Memory Diagnostic and see if it picks up any memory issues. RAM issues whether it's incompatibility or defective modules can cause seemingly random lockups.
When that happened to me, I would get some BSOD's.
I would concentrate on that SSD/HDD... Broken files/executables won't show up that often in security checks.
What I would do in your situation, is migrate your SSD to your HDD, maybe on a new partition. Unplug the HDD, install windows on that SSD with all updated drivers and such, and try to get them freeze ray moments again. If it's fine for a week or so, you know you had some kind of software problem/corrupted file. If the problem didn't get fixed, migrate back and look for a different problem. But I honestly think your problem is somewhere with the software/corrupted file. (if ram is ok)
*EDIT: AMD and freezing in one topic, without intel being called or talking about a person not freezing. How much fun!
  • 2 weeks later...
Ive ran the WMD and it took a couple hours and once my pc restarted there was no results or anything idk if I missed the results or whatnot but im not sure.
yeah I was falling into doing that. Let me try it out.
