Hello LTT members,
I was planning to build a new pc, moving on from my old laptop. I need a computer that can handle photo and video editing. My budget is $1000, and wifi card is a must. Don't need to add the monitor or peripherals. I will be price matching it with the cheapest places. thank you for the help.
my current build(i did go over $1000 CAD :( ):
CPU   $304.99       $304.99 Newegg Canada
CPU Cooler   $34.98       $34.98 DirectCanada
Motherboard   $89.98         $89.98 DirectCanada
Memory   $94.99       $94.99 Newegg Canada
Storage   $57.89       $57.89 Vuugo
    $89.50       $89.50 Vuugo
Video Card   $239.90       $239.90 Amazon Canada
Case   $53.95 -$15.00     $38.95 Vuugo
$15.00 mail-in rebate
Power Supply   $54.99       $54.99 Newegg Canada
Wireless Adapter         $22.98       $22.98 DirectCanada
Base Total: $1044.15
Mail-in Rebates: -$15.00
Total: $1029.15
https://ca.pcpartpicker.com/list/QRYZXH
https://linustechtips.com/topic/709360-next-pc-build/
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($289.98 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.98 @ DirectCanada)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($59.75 @ Vuugo)
Memory: Team Elite Plus 16GB (2 x 8GB) DDR4-2400 Memory  ($84.99 @ Newegg Canada)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($94.99 @ Newegg Canada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($89.50 @ Vuugo)
Video Card: PowerColor Radeon RX 480 4GB Red Dragon Video Card  ($254.99 @ Newegg Canada)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($39.99 @ Newegg Canada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($59.98 @ DirectCanada)
Wireless Network Adapter: TP-Link TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($22.98 @ DirectCanada)
Total: $1032.13
Generated by PCPartPicker 2016-12-19 22:38 EST-0500
idk
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057385
You need a z170 board to overclock that 6600k
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057386
I would ditch that and build this instead.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($304.99 @ Newegg Canada)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($24.99 @ Newegg Canada)
Motherboard: Asus Z170-P ATX LGA1151 Motherboard  ($129.99 @ Newegg Canada)
Storage: Patriot 120GB 2.5" Solid State Drive  ($55.69 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg Canada)
Video Card: PNY GeForce GTX 1060 6GB 6GB Video Card  ($326.98 @ DirectCanada)
Case: BitFenix Nova ATX Mid Tower Case  ($30.90 @ DirectCanada)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($62.98 @ NCIX)
Total: $1076.50
Generated by PCPartPicker 2016-12-19 22:43 EST-0500
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057408
Total: $1032.13
i was skimming through Video Editing 1060 or 480?  that the 1060 would perform better than the 480
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057415
That depends on the application. For example, Adobe Premier - and any Adobe program - will work far better with CUDA cores than Stream Processors. However, it's the exact opposite when it comes to Sony Vegas.
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057427
Keep in mind that 3GB 1060 has less CUDA cores and VRAM, where as 4GB 480 has all the power of its 8GB brother minus the VRAM.
idk
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057431
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($263.50 @ shopRBC)
CPU Cooler: Cooler Master Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler  ($23.00 @ Vuugo)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($43.50 @ Vuugo)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($89.99 @ Newegg Canada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($63.75 @ Vuugo)
Video Card: Zotac GeForce GTX 1060 6GB 6GB Mini Video Card  ($309.00 @ shopRBC)
Case: Cooler Master N200 MicroATX Mini Tower Case  ($38.95 @ Vuugo)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($58.98 @ NCIX)
Wireless Network Adapter: Rosewill RNX-N150PCe PCI-Express x1 802.11b/g/n Wi-Fi Adapter  ($14.99 @ Newegg Canada)
Total: $990.65
Generated by PCPartPicker 2016-12-19 22:47 EST-0500
If you don't want to overclock this would be a great build. I don't know if the 212 LED performs different than the evo but I heard its the same cooler with an LED fan slapped on. Might be wrong
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057438
i dont plan on using sony vegas, not ever, i use adobe photoshop, illustrator ...
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057439
For gaming it goes 470 < 1060 3gb < 480 4gb <= 480 8gb < 1060 6gb
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057450
Total: $990.65
that looks like a good build, might go up to a 6600(non K) and drop down the ssd storage? or increase the 1tb hdd to 2tb
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057451
Ah, then buy 3GB 1060. I don't create content, so just switch out the 480 with the 1060 3GB.
https://ca.pcpartpicker.com/list/pQgfxY
idk
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057452
Right, so check out the actual build I posted earlier. Quoted below-
Total: $1076.50
It has a better power supply and GPU, as well as a faster SSD and nicer-looking case. Believe me, I have the N300 and that series of cases is junk, and it has no side-panel window. That cooler also has a bright blue LED fan. It also has an overclocking motherboard, so you won't be stuck running your 6600k at stock speeds.
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057456
The 6600 non K and 6500 are the same performance. the 100mhz won't do much of anything
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057458
Total: $990.65
i really like this build, understanding that I don't need the i5-6600k, since overclocking is not a need for me. however, I will get a 2tb hdd
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057508
Total: $990.65
That cooler is a waste of money. You won't see any proportionate benefits unless you're going to overclock your CPU, and you can't overclock a Core i5 6500 or with an H110 motherboard.
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057529
i get that you can not overclock the 6500, and i will rarely be overclocking even if i get the 6600k
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057542
So it's $23 down the drain unless you really dig the LEDs.
What do you mean you will rarely be overclocking? Saying that you'll rarely be overclocking with an H110 motherboard and a non-K CPU is as stupid saying you're going to be blinded, and you will rarely watch movies.. It isn't possible.
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057568
sorry, i meant if i built the pc with the parts you recommended
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057595
Cheers, but overclocking isn't the only good thing about having a K-CPU and an overclocking motherboard. Keep in mind that hardware that can be overclocked is more futureproof, as it allows you to keep up with newer hardware simply by overclocking. So many people are using their Core i5 2500ks from almost six years ago and are not seeing an immense lapse in performance- they're still good for a lot of stuff.
Due to this, it also drastically improves the resale value of your build. In five years, a Core i5 6500 will be pretty useless. However, if trends continue, a Core i5 6600k will yield similar performance to the 10th-gen equivalent of the Core i5 6500. This is why people pay more for old computers with Core i5 2500ks and Core i7 2600ks in them than they would for builds with Core i5 2400s and Core i7 2600s.
https://linustechtips.com/topic/709360-next-pc-build/#findComment-9057618
