first build ever
im pretty sure i did good but i still want to be sure and avoid a bad surprise.
i used the little useful thingy that came with my asus z170-a motherboard, its very well written and clear.
the case is fractal design define s
http://imgur.com/a/kFoDi
https://linustechtips.com/topic/709295-are-my-headers-plugged-in-correctly/
THe power and reset are reversible, meaning there is no wrong way to plug them in.. as long as they are on the right header. All others are polarity specific, but judging from your picture, it appears you have everything correct.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
thank you sir.
2 minutes ago, Abyss Gaming said:
Looks fine to me, besides I don't think they short anything out if they are in the wrong spot...
famous last words
yeah first build ever so i suppose i was expecting a nuclear blast in case i didnt plug it correctly. lol, famous last words... i see what you did there.
i also have a set of pictures, and i am unsure about the audio header as it seems to sit weirdly in the pin connector, here you go
http://imgur.com/a/wI6ur
its not seating to the bottom of the connector...
as long as its in the JSB Audio? I think is the name, header.. the plug is keyed so it literally can only plug in 1 way.
Community Standards
"Beast Mode"
