Need help porting contacts to iPhone
Go to solution Solved by Daniel644,
Just now, techstorm970 said:
Verizon
there is an "app" for those older phones (including yours, I looked it up) called Backup Assistant download it to the phone, backup your contacts to the cloud and then download them to the new phone (this requires the old phone to still have active service) otherwise go to a Verizon Store, they should be able to do it there.
So I might be upgrading to an iPhone SE from a basic phone (LG Extravert 2) soon.  Problem is...my contacts can't be automatically transferred to the iPhone because the Extravert 2 isn't a smartphone.  Is there a way to transfer all of my contacts to the iPhone without writing down all my contacts on paper (or in MS Word) and then copying them one by one?  Please let me know.
Sorry for the mess!  My laptop just went ROG!
"THE ROGUE":  ASUS ROG Zephyrus G15 GA503QR (2021)
  • Ryzen 9 5900HS
  • RTX 3070 Laptop GPU (80W)
  • 24GB DDR4-3200 (8+16)
  • 2TB SK Hynix NVMe (boot) + 2TB Crucial P2 NVMe (games)
  • 90Wh battery + 200W power brick
  • 15.6" 1440p 165Hz IPS Pantone display
  • Logitech G603 mouse + Logitech G733 headset
"Hex": Dell G7 7588 (2018)
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • 1TB SK Hynix NVMe (boot) + 2TB Crucial MX500 SATA (games)
  • 56Wh battery + 180W power brick
  • 15.6" 1080p 60Hz IPS display
  • Corsair Harpoon Wireless mouse + Corsair HS70 headset
"Mishiimin": Apple iMac 5K 27" (2017)
  • i7-7700K
  • Radeon Pro 580 8GB (basically a desktop R9 390)
  • 16GB DDR4-2400
  • 2TB SSHD
  • 400W power supply (I think?)
  • 27" 5K 75Hz Retina display
  • Logitech G213 keyboard + Logitech G203 Prodigy mouse
Other tech: Apple iPhone 14 Pro Max 256GB in White, Sennheiser PXC 550-II, Razer Hammerhead earbuds, JBL Tune Flex earbuds, OontZ Angle 3 Ultra, Raspberry Pi 400, Logitech M510 mouse, Redragon S113 keyboard & mouse, Cherry MX Silent Red keyboard, Cooler Master Devastator II keyboard (not in use), Sennheiser HD4.40BT (not in use)
Retired tech: Apple iPhone XR 256GB in Product(RED), Apple iPhone SE 64GB in Space Grey (2016), iPod Nano 7th Gen in Product(RED), Logitech G533 headset, Logitech G930 headset, Apple AirPods Gen 2 and Gen 3
Trash bin (do not buy): Logitech G935 headset, Logitech G933 headset, Cooler Master Devastator II mouse, Razer Atheris mouse, Chinese off-brand earbuds, anything made by Skullcandy
https://linustechtips.com/topic/709185-need-help-porting-contacts-to-iphone/
4 minutes ago, MadMurl0c said:
You can login with your google account on your iPhone and sync your contacs if I remember correctly.
OP's old phone isnt a smartphone that supports that
you should be able to move your contacts from your phone, onto the SIM card
but im assuming its a different size SIM
you might have to do it manually
Photography / Finance / Gaming
What's a SIM card? :S
  • Ryzen 9 5900HS
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • i7-7700K
  • 16GB DDR4-2400
  • 2TB SSHD
  • Ryzen 9 5900HS
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • i7-7700K
  • 16GB DDR4-2400
  • 2TB SSHD
who is your cell phone provider? I know Verizon had a app I could download on my old phone years ago (before I got a smart phone, it was the app for ANY web capable phone, LG EnV Touch in my case) that would backup my contacts to Verizons Cloud that I could then download back to my new Smart Phone.
Verizon
  • Ryzen 9 5900HS
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • i7-7700K
  • 16GB DDR4-2400
  • 2TB SSHD
Verizon
